exporting design from polyboard to a 6 sided drilling machine|Forum|WOOD DESIGNER
Sorry, you must see with your administrator to update software before import,
OfflinePlease find attached PP used for this test,
Please update for free , information below
>https://wooddesigner.org/help-…..-software/
and download to the lastest installer version from link below
>https://wooddesigner.org/softw…..downloads/
after update from menu Files > PP options select import option
March 11, 2024
OfflineAlex said
Great news!Which version of PolyBoard have you got?
From menu Help > About
Following your version I can send PP used for this test files
it say PolyBoard 7.09a
thank you very much for the help, i asked for a piece of board with the same dimensions as your test file so i would run the program on the machine
Did you find solution to try MPR files?
Please unzip them before, else I can’t send them
Cheere
March 11, 2024
OfflineAlex said
Hi by looking file SyntecDxf.configIt look you have weel the default setting setting but now by test we need to find the good setting…
Can you try both files?
Only part and drilling on top and bottom
hello
unfortunately both files fail to load
OfflineHi by looking file SyntecDxf.config
