How to add a cover panel and add a longer plinth|Forum|WOOD DESIGNER
Hi, Alex thanks for the quick response.
I found the tutorials I needed with your direction but I seem to be having an issue where it is placing the ‘filler’ or plinth at the back of the cabinet as seen in the attached image.
The steps I took are as followed
1.Select both cabinets and floor in project mode
2. Right clicked and selected create filler put in my 18mm recess
3. Click ok
The filler is the correct size its just located at the back of the cabinets.
You can look this video,
https://wooddesigner.org/help-…..p-plinths/
and the associated videos, tools available in Polyboard 7 only
All the best, Alexandre
Hi, I’m just trying to add a cover panel on the end of a row of shelving units but I’m afraid I have forgotten how and cant seem to find a video for it. could you please point me in the direction of a tutorial on how to do this.
The other thing I have forgotten how to do is how to apply a single plinth across a row of units.
Matt
