Stairproject GZ|Page 2|Forum|WOOD DESIGNER
Stairproject GZ
January 23, 2023 - 9:26 am
Hi Michel,
The length is correct as in the PNG file you have sent me.  When I try to open the V2 file I get an error message, I have included a PNG showing the error. Can you advise?ErrorMessage.PNGImage Enlarger
Forum Posts: 990
January 23, 2023 - 9:11 am
Hi George,
You added on the wrong side of the riser. I corrected it myself. I just noticed that you did not add a landing step, but you extended the stringboards beyond the last step by 56mm. The smallest step in this setup is 60mm. In case you will have to reduce it upon production. This setup also means that the last step is not included in the flight length. So now, in fact, the total length of your stair is 5158.2 + 56 mm. If this is correct, please confirm otherwise, you need to correct this.
I attached the version with the correction on the risers. You always have to look in your 3D window in wireframe to see if a change has been done properly.
total-length.pngImage Enlarger
January 23, 2023 - 8:49 am
Hello Michel,
Thank you for your review. I have revised the drawing to implement your suggestions and attached a revised version.
If you can just check the revisions to ensure I have understood you correctly.  Thank you for your advice.
Kind regards
George
Forum Posts: 990
January 22, 2023 - 5:50 pm
Hi George,
Ok, it worked now. Everything looks fine. I only have a few remarks before sending the documents, as you have to be sure.
1 I do not see any penetration value from the riser to the lower side of the steps. It is usually 10mm.
2 the steps only penetrate the newel 5mm as it should normally have the same value as in the stringboards.
3 steps have an upper recess to the stringboards of 5mm. I would advise the same in the newels.
The stair as drawn is possible. I want to make you aware of what I found when checking. Point 1 is the most disturbing to me.
January 22, 2023 - 3:23 pm
Hello Michel,
I have shortened the filename.
KR George
Forum Posts: 990
January 21, 2023 - 11:04 am
Hi George,
no, it is not working. It needs to be a .stair  file extension. Please shorten the name as this is very long for a stairfile name
also, look at this post to see if you doing it correctly
https://wooddesigner.org/forum…..ing-files/
January 20, 2023 - 3:11 pm
Hello Michel,
I don’t understand as it loads fine on my pc.  I will try again, if for some reason it does not work can you email me and I will email you the file.
George
Forum Posts: 990
January 20, 2023 - 12:07 pm
Hi George,
You did not upload the correct file. Please recheck
January 20, 2023 - 10:00 am
Please process my stair file.
Guest(s) 24
Patrick Maylor: 63
Topics: 2105
Members: 260
