Doors
Polyboard allows you to add doors to your models in a number of ways. You can choose from single, double and sliding doors, you can have them open left/right or top/bottom. They can be built in or sit outside the carcass. You can apply edging and hardware exactly how you want, plus a whole range of other fine adjustments.
Adding and modifying doors
How to add single, double and sliding doors in Polyboard. Additional options we cover include built in and overlapping doors,...
Applied local feature: doors and drawers
The Applied Local feature works with doors as well as drawers as shown here). Normally you would set up doors...
Sliding doors with hidden rail
How to set up a panel to hide the rails that you would use to hang a sliding door. It’s...
Hanging door from a fixed panel
How to hang a door from a fixed panel, and apply hardware to it. The trick is to temporarily add...
