Need help whit my design|Page 5|Forum|WOOD DESIGNER
24
August 27, 2015 - 8:45 pm
Reodor said
Bought me up on their program a little while ago.
How do I see how much that should be cut / tapped out in bars?
Also wonder how I measure your steps?
23
August 27, 2015 - 10:47 am
August 27, 2015 - 10:40 am
Hi Reodor,
To print full size templates you have to load the DXf files into a CAD program and set up the printing.
If you don’t have a CAD program you can download the free  Draftsight from our members software download page here:
https://wooddesigner.org/membe…..raftsight/
Once installed you can open the DXF files in Draftsight and print them full size or add dimensions and print to scale.
The change in the overall dimensions is due to the fact that you have set up your stairs by fixing the outer left hand side dimensions.
Subsequent changes in sizes and thicknesses of components have maintained the inner sizes and changed the overall outer dimensions.
If you need the stair to have 132 outer dimension the working documents you have will not be correct and we will either have to regenerate the working documents to the right size or modify the existing documents.
You could just make the last step wider but you will also need to change the position of the post.
For a fuller more detailed revision of your project, I suggest you buy a StairFile Pro so that I can take the time necessary to look at the details of your project .
21
August 27, 2015 - 7:56 am
How do I do this for the template?
Format to print in? File?
Have you a tip for the milling?
See that page dimensions are changed slightly, I can adjust this with the last step?
Right and left side has 132.
August 26, 2015 - 4:40 pm
Hi Reodor,
The files don’t seem to have uploaded, I might have made a mistake, sorry about that.
Here they are again.
19
August 25, 2015 - 6:15 am
Hi
I can not see anything.
August 24, 2015 - 5:23 pm
Hi Reodor,
Here are the working documents for you stair.
I hope they will work for you and wish you good luck with the building.
Keep us updated as to how it goes.
17
August 24, 2015 - 6:30 am
Hi
The project is located further down the page here, you helped me with this!
August 19, 2015 - 6:47 pm
Hello Reodor,
You don’t seem to have uploaded your stair project file.
To upload a file click the upload attachments button below and drag the file into the upload window.
Then don’t forget to click the Start Upload button before posting.
Looking forwards to seeing your project.
15
August 18, 2015 - 1:52 pm
please help me and take it away, while I think this is ready for processing,
or what do you think? I’ve forgotten something?
Guest(s) 12
Zaheer Abbas: 88
Patrick Maylor: 63
almys111
Topics: 2107
Members: 261
