1. Home
  2. Help Centre
  3. Installation
  4. Upgrade from OptiNest 2 to 3
  • This guidance is for OptiNest version 2 users upgrading to version 3
  • OptiNest 2 must be on the same computer as OptiNest 3
  • Follow these steps before uninstalling OptiNest 2
If you wish to save and restore your settings in OptiNest 3 or above only, please read the FAQ: How do I save and restore my settings?
Save and restore your settings
In OptiNest 3 go to Tools menu > Options > Restore OptiNest 2 settings.
window for restoring parameters in the OptiNest software
PolyBoard (optional)
Only applicable if you use OptiNest with PolyBoard.
PolyBoard post processor settings
PolyBoard users must upgrade to PolyBoard 7.10u or higher to activate the following post processor setting for exporting to OptiNest 3.
post-processor options window in OptiNest software
Restore panel stock
Note that each panel must be associated with a material.
In OptiNest 2 go to Tools > Options > General > Stock folder.
Copy the access path.
optinest 2 stocks folder
In OptiNest 3 go to Tools > Folders > Settings.
Paste the previously copied path to the Stocks line.
access path to the stock folder in the OptiNest software
Multi-material function
OptiNest 3 has a new multi-material function, you can now use the same library of materials for PolyBoard 7 and OptiNest 3.
In PolyBoard 7 go to Tools > Folders > Settings.
Copy the materials path.
access path to the materials folder in the PolyBoard software
Paste the previously copied path to the Materials line.
access path to the materials folder in the OptiNest software
Additional references
These are now configurable in OptiNest 3 for PolyBoard 7 users.
Go to Tools > Preferences.
Preferences window in OptiNest
Set the number to 8 and define as follows:
  • Cabinet
  • Project
  • Cutting list number
  • Working area
  • PostPro 2_F1 (related to multi post processor export)
  • PostPro 2_F2
  • PostPro 3_F1
  • PostPro 3_F2
