Galley kitchens, which are so called in recognition of the narrow cooking quarters found on ships, tend to be commonly found in apartments, studios or smaller homes.
Though it may seem like a limitation to have such a tight passage, a galley kitchen proves that there is much more than meets the eye when it comes to style and functionality.
With proper planning and smart design choices, you can create a culinary oasis out of your galley kitchen that maximizes space and brings joy.
Galley Kitchen Design
Embracing efficiency: the core principles of galley design
  • The culinary golden triangle: this principle is premised on positioning the refrigerator, sink and range cooker forming a triangle to reduce movement while preparing food
  • Adequate storage space: utilize all vertical spaces with tall cupboards plus mounted shelves along walls; deeper cabinets should have pull-out drawers and lazy susans for better accessibility
  • Clean lines and light: in order to foster an atmosphere of openness within the limited space available, choose sleek countertops as well as streamlined hardware with light reflective finishes
  • Multi-functional elements: furniture or appliances that conveniently serve more than one purpose such as breakfast bars doubling up as countertops
Wooden Galley Kitchen Top
Smooth sailing: layout options for your galley kitchen
The best layout for your galley kitchen depends on the specific dimensions and configuration of the available space. Here are some common layouts to consider:
  • One-wall galley: all appliances and storage are positioned along a single wall, creating a streamlined workspace; this works best in extremely narrow kitchens
  • Two-wall galley: this layout offers more countertop space and storage by placing cabinetry on both opposing walls; make sure there’s enough space to walk between the countertops
  • U-shaped galley: for three-wall usage maximizing storage and counter space is ideal for wider galley kitchens but might feel cramped in very small spaces
Long Galley Kitchen
Beyond efficiency: adding personality to your galley kitchen
While functionality reigns supreme, don’t forget about aesthetics! Here’s how to infuse your personality into your galley kitchen:
  • Flooring: consider opting for light or formed ceramic tiles that develop aesthetic passion; you might choose wood floorings to include a level of warmth
  • Kitchen counters: consider quartz or granite as products for a sophisticated appearance or butcher block for rustic beauty
  • Backsplash: a declaration backsplash can include a sprinkle of shade or pattern plus shield your wall surfaces from spillages; repurpose floor tiles, mosaic patterns and even a vibrant feature wall surface
  • Illumination: harmonious layered lighting is crucial; recessed lights, pendant lamps over the sink or breakfast bar and also under-cabinet lights can be made use of for added detail
Galley Effect Both Sides
Styles that inspire in a small space
  • Minimalist dream: get a smooth finish with a modern appearance with tidy lines, white cabinets, as well as stainless-steel home appliances
  • Rustic charm: make use of revealed block wall surfaces, butcher block kitchen counters, along with open shelving to produce warmth
  • Coastal getaway: bring light blue cabinets, whitewashed timber, as well as nautical-inspired equipment right into your kitchen area to offer a beachy feeling
  • Strong as well as beautiful: don’t avoid shade; consider selecting deep environment-friendly or navy closets with brass equipment to add functionality and a talking point
Kitchen in the Roofspace
Keep in mind that a properly designed passage cooking area isn’t just about appearances; you should also be concerned with making certain it matches your food preparation aspirations while making the most of the available space.
By combining one-of-a-kind design with smart layout concepts, you will certainly wind up refurbishing your galley kitchen into an effective yet sophisticated cooking and food preparation area.
If you would like to design your own kitchen, please consider our CabinetFile service, a great way to use free cabinet design software and access expert support along the way.
